Knowledge Base Article
*** Fatal Error: Segment Violation at (nil)
Description
When you enable the SKP Detection logic in Gen3 mode for the Arria® 10 Hard IP for PCI® Express in Quartus® Prime 15.1.2 this fatal error may be seen.
The timing constraint file, altera_pcie_a10_skp.sdc, is auto generated for the SKP Detection logic. If this .sdc file is read before the PLL clocks are derived, you will encounter this Quartus Internal Error.
Resolution
To work around the Quartus Internal Error, read the altera_pcie_a10_skp.sdc file after the corresponding PLL clocks are derived. You should run derive_pll_clocks first before running this .sdc file. Ensure the .sdc file that includes derive_pll_clocks is listed before this file.
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Related Articles
Updated 1 month ago
