Knowledge Base Article
*** Fatal Error: Program termination requested. Quartus 0x23d8f: err_terminator() + 0x1bc (ccl_err)
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, you might see this error when the names of the instances in Signal Tap match the clock names.
Resolution
To work around this problem, rename the instances on Signal Tap so they no longer match with the clock names. This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
