Knowledge Base Article
*** Fatal Error: Int Divide By Zero
Description
Due to a problem in the Quartus® II software version 11.0 and later, you may see a fatal error during synthesis if your Verilog HDL code contains a port width evaluation where either the MSB or the LSB results in a negative number. The following example code will generate this fatal error.
parameter ADDR_WIDTH = 0;
input [ ADDR_WIDTH-1:0] address;Resolution
To work around this problem, do not create ports with a negative MSB or LSB.
A future version of the Quartus II software is scheduled to report an error message describing the problem instead of producing a fatal error.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
