Knowledge Base Article
******* Error: Assert failure at /lib/FPGASupport/ACLUtils.cpp(5861) *******:
Description
Due to a problem in the Intel® High-Level Synthesis Compiler Pro Edition version 21.1, you might see an error when using a third-party library function.
Resolution
This problem is fixed beginning with version 22.3 of the Intel® High-Level Synthesis Compiler Pro Edition software version, where the compiler will display a proper error message.
Updated 2 months ago
