Knowledge Base Article
// Error: <design file>:29:20: "A_WE_StdLogicVector" invalid expression.
Description
Due to a problem in the Quartus® II software version 11.0 SP1 and later, the <proj rev>.ctc script file created for Cadence Encounter Conformal Logical Equivalency Check (LEC) software is missing a line to include the file altera_europa_support_lib.vhd. This missing line may cause the above error.
Resolution
To work around this problem, add the following option line to the read_design command in your <proj rev>.ctc script file.
- map altera /libraries/vhdl/altera \Updated 3 months ago
