Knowledge Base Article
​​​​​​​Which Agilex™ 5 IP features have limited hardware validation in the Quartus® Prime Pro Edition Software v24.2?
Description
The Quartus® Prime Pro Edition Software version 24.2 provides limited hardware support for Agilex™ 5 IPs or features as per the table below. Additionally the device models, bitstreams, and firmware for the devices are not finalized.
Known issues impacting specific functionality of Agilex™ 5 can be referred to Agilex 5 Knowledge base Article Search.
Resolution
Device Features/IP
IP/Functions Not Validated in Hardware for 24.2
Transceiver
GTS PMA/FEC Direct PHY FPGA IP
PCS Direct Mode
Tx/Rx Simplex
"Analog Parameter" options (except default values)
GTS Reset Sequencer FPGA IP
GTS System PLL Clocks FPGA IP
GTS Transceiver Toolkit
FEC options
Ethernet
GTS Ethernet FPGA Hard IP
SyncE, MAC Features (SFC, PFC, CRC), Manual Adaptation
Client Loopback in ED
Low Latency 40G Ethernet FPGA IP
SyncE, MAC Features (SFC, PFC, CRC).
Triple-Speed Ethernet FPGA IP
Loopback on MII/GMII, RGMII Interface, Flow Control, Align-Packet Header with 32-bit
Ethernet Toolkit
Multi instances without PTP
External loopback with PTP
PCIe
GTS AXI Streaming FPGA IP for PCI Express
Example design,PTM
Interlaken
GTS Interlaken FPGA IP
IP not validated in hardware
JESD204
JESD204C GTS FPGA IP
PHYLITE
PHY Lite for parallel interfaces FPGA IP
HPS
Processors and Peripherals
Embedded software readiness
Video
DisplayPort FPGA IO
GTS DisplayPort Phy Altera FPGA IP
GTS HDMI FPGA IP
Processors and Peripherals GTS SDI II FPGA IP
Updated 3 months ago
Version 2.0
