grit's avatar
grit
1 month ago
Why does the system report an error when generating rbf from sof files and fsbl files?
Error message:
Error: Internal Error: Sub-system: BITASM, File: /quartus/pgm/bitasm/bitasm_common_code.cpp, Line: 518 HPS data start address(-1950584) is not 16 aligned
Device and tool information:
  1. The device used is Stratix 10 1SX110HN2F43I2VG, without using the Stratix 10 SoC Development Kit;
  2. Quartus Prime Pro25.1.1
  3. U-boot source code:u-boot-socfpga-socfpga_v2025.04
  4. ATF source code:arm-trusted-firmware-socfpga_v2.13.0
Operation steps:
  1. Simplified the Platform Designer section of the Stratix 10 GHRD project;
  2. 【Device and Pin Options】->【Configuration】Set the HPS/FPGA configuration order to be HPS First;
  3. The Quartus full compilation generates the sof file in the "output_files" directory;
  4. Compile the ATF source code, and obtain the bl31.bin file in the path of ./build/stratix10/release;
  5. Copy the bl31.bin file to the root directory of u-boot, compile the u-boot source code, and obtain the u-boot-spl file in the ./spl/ directory;
  6. Convert u-boot-spl to u-boot-spl.hex and copy it to the output_files directory;
  7. Open the Programming File Generator tool and configure the Output Files:
  8.  Configure Input Files, add sof and HEX files:
    9. Configuration Device:
    10. Generate error:
