ohfpga1's avatar
ohfpga1
1 month ago
Timings eMMC
latest datasheet of SoC « 813918/2026.01.05 » lists in paragraph « HPS SD/eMMC Timing Characteristics » the constraints of eMMC, applicable to memory component but does not define any timing data in input/output of SoC.
There is no Tco min/max of CMD/DATA at SoC output, as well as Tsetup/hold of CMD/DATA at SoC input.
Can you provide Tco and Tsetup/hold for eMMC usage (Legacy, HS_SDR, HS_DDR, HS200, HS400) ?
thanks
  • ohfpga1's avatar
    ohfpga1
    Hi Kian, do you have any feedback from factory ?
    thanks
  • KianHinT_altera's avatar
    KianHinT_altera
    Apologies, didnt notice you mentioned you're already referring to the 813918, I'm checking with our factory team and let you know later.
    Kian
    KianHinT_altera
    Hi ohfpga1
    Could you refer to the Agilex 5 datasheet under SD/EMMC timing characteristics (https://docs.altera.com/r/docs/813918/current/agilextm-5-fpgas-and-socs-device-data-sheet/agilextm-5-fpgas-and-socs-device-data-sheet)
    Example for legacy, HS_SDR
    There is also timing tables for the rest of the modes eg (HS,HS200, HS400). Could you refer to the document and see whether it addresses your timing question?
    Kian
      KianHinT_altera
      Hi ohfpga1 ,
      I've gotten a reply on our factory on the your question as I was asking them whether Tco & Tsetup/hold is it correspond to the Tisu, Tih,  Todly etc. They would like to understand further on your query on what spec are you looking for , it is something like on Figure 12/13?
      Kian
