Bhanu_LFT
18 days agoSupport Request to Debug Signal Tap Issue with SoC Based Design(GHRD) on Agilex-7 FPGA
Hi Altera Support Team,
Greetings from Logic Fruit Technologies.
This is Bhanu Pratap and I am working on the project in which we are using Agilex-7 SOC FPGA.
Goal: Utilize Agiliex-HPS's capability on a Linux OS to control dynamic features of IP Cores at runtime.
Problem Statement: We are facing an issue detecting SignalTap with SoC-based designs for runtime debugging while it's enabled and added from the Quartus project to generate the programming file.
Brief Description:
- We are using Quartus 2025.1.1 and Altera's Agilex-7 Devkit(DKSIAAGI027FA: Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit -> 4x F-Tile, Rev C).
- We downloaded the base GHRD design from Altera's GitHub webpage for the corresponding Quartus version.
- We are following each step to test GHRD and build generation for the Linux OS.
- We are using HPS First booting mode, we generated the build without modification and tested it. It's working fine according to the GSRD user guide.
- We have added a custom AXI4 Slave based CSR module to the HSP Lightweight bus to test basic register read/write using Platform Designer.
- We regenerated the build and re-tested but we are not getting the expected results so we added SignalTap for debugging.
- Build is generated using the STP file, programmed, and the OS is booting but it's not detecting SignalTap.
This looks more like a process gap. We seek your support to fix this issue.
Note: If we use an FPGA design without HPS, we are able to add and detect SignalTap.
Seeking for urgent support.
Bhanu Pratap
