RLambdin92's avatar
RLambdin92
16 days ago
Stratix 10 GSRD Development Issues
Currently working with the GSRD Users Guide from the Rocketboards archives (https://altera-fpga.github.io/rel-24.3/embedded-designs/stratix-10/sx/soc/gsrd/ug-gsrd-s10sx-soc/#partial-reconfiguration_1). Have been attempting to try and better understand the Partial Reconfiguration portion of the design and have made some attempts at trying to modify the design and rebuild from there.
I've walked through the process fully to get the initial build fully developed and working. I then attempted to edit the top level of the design by disconnecting the user LEDs from the Qsys Top and hard coding their values. I went through the entire process again and replaced the ghrd_s10_top.sv with the LED changes before running "make all". Going through the entire rebuild process and the Yocto rebuild, I produced a JIC and SDCard Image which i loaded the same way as the working build. But when I attempt the "dtbt" device tree to apply either Persona, the command gets stuck and pushes a "Stratix10 SoC FPGA manager soc:firmware:svc:fpga-mgr: timeout waiting for svc layer buffers".
Looking for any assistance on the process of applying changes to the design and rebuilding this PR design. Thanks for any assistance
  • Let’s clarify both the environment separation (Quartus vs. Yocto) and the static region modification concerns in the context of Intel Stratix 10 Partial Reconfiguration (PR):
    Environment Separation: Quartus vs. Yocto
    Short answer:
    It’s perfectly fine to run Quartus (hardware build) and Yocto (Linux image/device tree build) on separate machines, as long as you maintain the integrity and synchronization of the files between them.
    What must be consistent?
    • The actual generation of SOF, RBF, JIC files must happen in one coherent Quartus environment (same project directory and version).
    • These generated files (.sof, .rbf, .per.rbf, .jic, handoff files, etc.) are then transferred to your Yocto build machine for inclusion in the Linux image, device tree overlays, etc.
    • Do not mix RBFs or JICs from different Quartus projects, or from different versions of Quartus.
    • Yocto: Can be run on any machine, as long as it uses the correct hardware files and handoff files from your Quartus build.
    Best practice:
    After you finish all Quartus builds and have your output files, copy the entire set of relevant outputs to your Yocto machine. Always keep them matched as a set.
    How to Verify PR Hash Consistency
    You can use the quartus_pfg -i command to inspect the PR hash and other metadata in your SOF and RBF files.
    The PR hash must match across all images from the same build.
    Example Commands:
    quartus_pfg -i ghrd_1sx280hu2f50e1vgas.sof
    quartus_pfg -i stratix10_htile_pr_ghrd.core.rbf
    quartus_pfg -i stratix10_htile_pr_persona0.rbf
    quartus_pfg -i stratix10_htile_pr_persona1.rbf
    Modifying the Static Region (GHRD_S10_Top.sv and LED Example)
    Static Region & PR Interface:
    • The static region is the part of your design that does not change during partial reconfiguration.
    • The PR region is the area that can be reconfigured at runtime with different "personas" (bitstreams).
    Key Rule:
    You can change anything in the static region, as long as those changes do NOT affect the boundary/interface between the static region and the PR region.
    • If your GHRD_S10_Top.sv changes only involve logic or signals that are fully within the static region, and do not touch or alter the ports, signals, or interfaces that connect to the PR region, then it’s fine.
    • However, if you change anything at the boundary (for example, change the width, type, or presence of a signal that connects static to PR), you must update every persona and the static region, and keep them all in sync.
    You can post a snippet of your changes to GHRD_S10_Top.sv and a block diagram of your static/PR region boundary, and I can help confirm if your changes are safe!
    Let me know how it goes when you get back to the hardware!
  • Thank you for the update. I’m glad to hear the partial reconfiguration functionality is working. I will mark this case as closed.
  • RLambdin92's avatar
    RLambdin92
    Got the test run and while the LEDs don't match up, thats more user error. The PR functionality does not lock up anymore. Appreciate all the assistance!
    RLambdin92
    I've replicated the working build once again after noticing that I was not operating in the correct Quartus Version. I'm currently running the build with the change in the Static Region (agnostic of any PR connections). Will be running the Yocto script as I head out of the office and am testing this in the morning. If it works, think I will have my process down and can mark up the post as solved. If there are issues, I'll post them up in the morning.
    RLambdin92
    Did a quick test but the quartus_pfg -i command does not appear to support RBF files. I can --check_integrity but i don't know if this is doing the same process.
    EDIT:
    Ignore the top. After troubleshooting, I realized the terminal I had open was not correctly set to Quartus 24.3 so I'm rectifying this. Trying to readjust the test now.
    RLambdin92
    Never knew of the command to check the files! This is a great revelation! Does this command work over a JIC as well? Or should this be done before generating the JIC file used for the SD Image process?
    Getting everything kicked on but will report back before lunch how things are going.
    Short answer:
    Best practice:
    Example Commands:
    Key Rule:
    RLambdin92
    Running through these steps and will report back tomorrow when I can test on hardware. Inclement weather has trapped me at home away from the hardware.
    But one thing I would like to review. I work in a setup which I have to bounce between because my Quartus setup is setup away from an internet connection, thus I need to run the Yocto setup on another machine. Since this seems like a separate process, I don't think this is an issue. But if the other aspects need to be the same, then any generation of SOF, RBF, or JIC need to be in that same Quartus environment? I may have crossed those in the past so trying to confirm one way or the other.
    Also with changing the Static Region, the goal was to keep that change consistent throughout every PR region as well. To my knowledge, changing the LEDs in the Static top shouldn't be problematic if its agnostic of the PR region interfaces. The only file I've changes has been the GHRD_S10_Top.sv file. Am I miss understanding this concept?
  • The error you’re seeing:
    is a common symptom of a design or flow mismatch, especially in the context of Partial Reconfiguration (PR) on Intel/Altera devices. Here’s a breakdown of what’s likely happening and how to address it.
    Key Points with Stratix 10 Partial Reconfiguration
    1. Static/PR Region Interface Consistency
      • The interface (ports, connections, parameterization) between the static region and the PR region must remain absolutely unchanged between personas and after modifications.
      • Any change to the interface (even disconnecting signals or hardcoding values) can cause PR bitstreams to be incompatible or cause the system to hang (as you are seeing).
    2. Device Tree and Bitstream Pairing
      • The Device Tree Blob Overlay (dtbo) and bitstreams must match the actual hardware design. If you change the hardware, you must regenerate all PR personas, the static region, and update the device tree accordingly.
    3. Firmware Service Layer Timeout
      • This timeout typically means the FPGA manager tried to apply a PR bitstream, but the hardware (static+persona) is not compatible, or the handoff between Linux and the FPGA manager is broken due to mismatched or corrupted images.
    Recommendations for Your Flow
    1. Ensure Interface Consistency
      • Do NOT change any port widths, names, or remove connections between the static region and the PR region. If you must hardcode LED values, do it inside the PR region (persona) rather than at the static top level.
      • The static region must be identical for all personas and for the base image.
    2. Rebuild Everything
      • After making changes, re-run the full Partial Reconfiguration flow
        • Re-generate the static region (base image).
        • Re-generate all PR personas.
        • Re-export the Qsys/Platform Designer system.
        • Rebuild the device tree with updated hardware descriptions.
    3. Check Qsys/Platform Designer Connections
      • If you disconnect signals in Qsys, make sure you do so only within the PR region.
      • The handoff files used for PR must match the actual design.
    4. Bitstream and Device Tree Synchronization
      • Make sure the bitstreams (.rbf, .per.rbf, etc.) and the device tree overlay you are applying are both built from the same version of the hardware design.
    5. Test Static Region First
      • Program only the static region (no PR) and boot Linux. Verify that the system is stable and accessible before attempting to load a PR persona
      • If the system fails at this stage, the issue is likely with the static region modification.
