Okay, can you see the below logs, below logs shown that the first two initial logs where it needs an FPGA configuration done before booting the SPL, after the two initial logs, the FPGA is programmed successfully using Quartus Programmer, you can see the U-boot SPL loading and go into U-boot user mode, did you see this behavior? Does this fits your design requirement?:
U-Boot SPL 2022.04-21230-gfcf317324c-dirty (Oct 20 2022 - 05:12:31 +0800)
FPGA: Checking FPGA configuration setting ...
WDT: Started watchdog@ffd00300 with servicing (10s timeout)
Trying to boot from SPI
QSPI: Invalid input arguments txlen 64
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
DDRCAL: Success
DDRCAL: Scrubbing ECC RAM (1024 MiB).
DDRCAL: SDRAM-ECC initialized success with 146 ms
U-Boot 2022.04-21230-gfcf317324c-dirty (Oct 20 2022 - 05:12:31 +0800)socfpga_arria10
CPU: Altera SoCFPGA Arria 10
BOOT: QSPI Flash (1.8V)
Model: Altera SOCFPGA Arria 10
DRAM: 1 GiB
Core: 69 devices, 16 uclasses, devicetree: separate
Loading Environment from SPIFlash... SF: Detected mt25qu01g with page size 256 Bytes, erase size 4 KiB, total 128 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net:
Warning: ethernet@ff800000 (eth0) using random MAC address - 52:6c:4d:8d:5c:15
eth0: ethernet@ff800000
Hit any key to stop autoboot: 0
