Vince
7 years agoWhen using the "DDR3 SDRAM Controller with UniPHY" why does the generated .sdc specify the DDR3_ck and afi_clk at 80% of their specified rate from Qsys?
In Qsys I specify the "Memory clock frequency" as 500MHz. After compilation I run the timing analyzer, when I run "Report Clocks" it shows: DDR3_CK: 400MHz pll_afi_clk: 200MHz When I run "Report F...
NurAida_A_Intel
7 years agoHi Vince,
May I know what is the speed grade of the device used? It would be better if you can share with me the full part number of the device 😊
Also, is there other clock source used beside afi_clk? The reason I ask this because using another clock would cause Qsys to automatically instantiate clock-crossing logic, potentially degrading performance.
NAli1
