17 years ago --- Quote Start --- ... I was talking about the value set in the PLL Megafunction, not in the SDC. I am not setting any frequency or period in the constrain file, but making TimeQuest to derive the frequencies from the PLL setting. The problem is that both the Fitter and TimeQuest, take the PLL output frequency from the user selected value, not from the actual value (the PLL output clock as a result of the master clock division and multiplication) that sometimes is slightly different. The difference is quite small, probably not significant. So just a buglet in the worse case. --- Quote End --- If your PLL settings in the MegaWizard can't be implemented exactly, you probably got compilation messages (it seems like they happen in the Fitter, but I don't remember for sure) comparing the requested settings and the settings actually being implemented. I prefer to change the MegaWizard settings to the actually implemented values to get rid of these messages about the mismatch.
