TimeQuest can't analysis the clock from the PLL
The problem is as follows.
I need a MUX to switch the clock between normal mode and test mode. And I don't care about any transient state when clock switching.
The ending shows the design. 'pll_c4_sw' is the switched output clock. Some IP use 'pll_c4_sw' as a clock. 'pll_c4' is the clock from the PLL. 'clk_pin' is the input clock from the combinational circuit.
( I use ALTPLL to generate pll_c0~pll_c5.
Unfortunately, Quartus13.1 tell me that "PLL "pll|altpll_component|auto_generated|pll1" has parameters clk4_multiply_by and clk4_divide_by specified but port CLK[4] is not connected." when I use the Stratix III device. TimeQuest can't also analysis the timing on pll_c4 becuse TimeQuest can't find pll_c4 which is equal to clk[4] after Fitter.
Could someone please tell me what happen there? Thank you very much.
Design:
assign pll_c4_sw = sel? pll_c4 : clk_pin;
SDC command:
create_generated_clock -name pll_c4 -source [get_pins pll|altpll_component|auto_generated|pll1|inclk[0]] -multiply_by 1 -divide_by 4 [get_pins pll|altpll_component|auto_generated|pll1|clk[4]]
Hi SyafieqS_Intel, finally, I use the command, /*synthesis keep */, to keep relative port so that TimeQuest can find the CLK[4] port of the PLL.
The CLK[4] port of the PLL in post-fit is "pll|altpll_component|auto_generated|pll1|clk[4]". Thank you, SyafieqS_Intel, very much.
- sstrell
Are you saying the design doesn't synthesize? Maybe you have illegal PLL settings.
Can you show screenshots of the parameter editor (Megawizard)?
- NuvKFC
Contributor
Hi sstrell, thank for your suggestion.
The design can be synthesized and APR. Unfortunately, Quartus13.1 miss the CLK[4] port of PLL after Fitter so that TimeQuest can't find the CLK[4] port of PLL to analysis. Following pictures are the PLL Megawizard and PLL usage. The differences among clocks of PLL only are the multiply parameter and divide parameter. I don't know what's wrong here.
Warning: CLK[4] isn't connected.
PLL Megawizard:
PLL usage:
- sstrell
What is the logic for sel to the mux? If it's not switching, the clock may have been optimized away. As you can see, clock 4 doesn't even show up in the PLL usage report. This is why I suggested previously to add a clock control block and use the switching there instead of creating a mux like this.
You can try to confirm the clock was optimized away by looking at the post-fit Technology Map Viewer and see if you see the clock coming out of the PLL at all. You could also check the compilation report for warning messages about the clock being optimized away or other reasons why it may have disappeared.
- SyafieqS
Hi Kfc,
May I know if there is any updates?
- NuvKFC
Contributor
- SyafieqS
- NuvKFC
Contributor
Hi SyafieqS_Intel, OK, no problem,. Thank you very much.
