9 years agoSDC - What clock should the input pin be relative to?
Hello, signal_x in an input pin to my FPGA. signal_x is synchronous to clock_x which is also an input pin. clock_x drives a pll input and becomes pll_clock_x. pll_clock_x is pha...
9 years agodo you mean you haven't declared the base clock of 40MHz? you need that even though PLL is connected to it.
Look at the failedpath table: what is the figure for setup relationship.This should be 25ns. your set input delay of.1/10 means early margin is very close to edge. Is that how your external chip and board delay wants? is your pll in normal mode or any other mode?
