- paveetirrasrie_Altera
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
Hello Hanssi,
Good day to you.
Does the suggestion from our contributor helped? Kindly do let us know if you need further clarifications.
Pavee
- sstrell
Your setup in Quartus doesn't really matter for your issue since you're using the Lite edition.
As for QuestaSim, it looks like you have the environment variable set up correctly. Is this a newly generated license file? Open up the .dat file and check the date and that the MAC address is correct for a network interface on your computer.
You should also run lmutil lmdiag as suggested.
