11 years ago --- Quote Start --- 1) When attempting to enable TalkBack via Tools/Options/Internet Connectivity/TalkBack Options/"Enable sending TalkBack data to Altera", I check the box and OK out of both menus, but the change is not saved. Reopening the TalkBack Options pane immediately after (without restarting the software or the system) shows the box as unselected. This is a serious issue, as it is preventing me from using the SignalTap II IP core under the Web Edition license. --- Quote End --- The settings are in .altera_quartus directory in your home directory in the quartus2.ini file. The settings are version specific. Check to make sure this directory, and file are owned by you and writable. --- Quote Start --- 2) When adding licenses, I must manually specify licenses each time after starting the software up. This is an issue when integrating 3rd party IP core licenses. --- Quote End --- Use the LM_LICENSE_FILE environment variable if you have issues.
