11 years agoQuartus Not Saving Important Configurations
I am encountering an issue where my Quartus II 13.1 Ubuntu install is not able to save the changes I make to important settings. This is an issue for me since it is preventing me from leveraging important features within Quartus that rely on having a certain license or configuration. Here are two cases that I have run into:
1) When attempting to enable TalkBack via Tools/Options/Internet Connectivity/TalkBack Options/"Enable sending TalkBack data to Altera", I check the box and OK out of both menus, but the change is not saved. Reopening the TalkBack Options pane immediately after (without restarting the software or the system) shows the box as unselected. This is a serious issue, as it is preventing me from using the SignalTap II IP core under the Web Edition license. 2) When adding licenses, I must manually specify licenses each time after starting the software up. This is an issue when integrating 3rd party IP core licenses. Installation Details: Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition Web Edition License OS: Ubuntu 13.10 64-bit, fully patched Thanks for your help! Matt EDIT: I should add that I tried running Quartus under sudo thinking that there might be a write permissions issue at play, but the process crashes immediately.
