15 years agoIf your interface is DDR then you need further additions for falling edges.
see Timequest resource centre on altera.com With regard to 8 ns setup time of ADC, I am not sure what you mean because ADC is an outputting device, only its tCO matters. May be you mean maximum/minimum tCO or skew at ADC output, in that case it is fair enough to use that figure as range diff between max/min.
