ElShang's avatar
ElShang
1 month ago
Once again about CTRL+L
Hello.
Consider this message as mere feedback. I moved from Quartus 20.1 to 25.1 and discovered that now what Ctrl+L does depends on the focus: it deletes a line if in the text editor and starts the compilation in other cases. That's quite inconvenient, if you ask me. And there was already a thread dedicated to this peculiarity
From my standpoint, the keyboard shortcut must do one and only one thing. :-) Maybe developers will take that into account for that in the future.
Also, if there is a possibility to fine-tune shortcuts — point me in that direction. I failed to find that.
  • ShengN_altera's avatar
    ShengN_altera
    I had reflected the problem to internal engineering team and will be fixed in future version. Currently please stay with the workaround that close all the file/text editor before press CTRL+L to run compilation.
    • FvM's avatar
      FvM
      Or use ALT+R C key sequence.
  • FvM's avatar
    FvM
    Yes, CTRL+L has no effect in Quartus Pro text editor, only in Quartus Std/lite.
    Apparently few people are using CTRL+L shortcut, so the bug survived five major Quartus releases.
    The superfluous keyboard shortcut is neither listed in Quartus help nor text editor edit menu.
      ShengN_altera
      Understood that. I'll reflect this problem to internal engineering team.
    ShengN_altera
    Sorry for confusion. If for Pro, there's no issue.
    Do you mean Standard Edition? If Standard, I'm seeing the problem. I'll reflect this problem to internal engineering team.
  • FvM's avatar
    FvM
    I can confirm the observed behaviour. Since Quartus 21.1 Std (don't have 20.1 installed presently), CTRL+L is deleting the current line if editor is open and has the focus. I don't have any editor customizations applied.
    Frank
    ShengN_altera
    I test on v25.1 without any problem. Could you try re-open project and try again?
