12 years ago
Modelsim Error: (vcom-7) Failed to open design unit file "..." in read mode
Dear all,
There is an error I need your suggestions:
Error: (vcom-7) Failed to open design unit file "directory/file name" in read mode. Can you inform me how I can overcome it?
I am using ModelSim Altera Starter 10.1d with Quartus II 13.1.
Thanks!
1 Reply
    Modelsim only does what you ask, so you need to look at what you are asking it to do :)
    For example, how are you getting Modelsim to attempt to compile this file? Are you asking Quartus to run an RTL simulation, or are you running a Tcl script?
    Chances are you have an invalid filename that you are trying to pass to vcom, eg.,
    vcom c:/vhdl/my_vhdl_file.vhd
    would work, but
    vcom c:\vhdl\my_vhdl_file.vhd
    would not, since the backslash is a Tcl escape character, but ...
    vcom {c:\vhdl\my_vhdl_file.vhd}
    will work, since it passes the path without interpreting the contents of {}
    You might also look for spaces in your paths ... they can be used, but you have to use "" or {} to pass the path as a "single string", since that is what Tcl wants to see.
    Cheers,
    Dave
