Modelsim design size limit buggy and or misleading in Quartus Lite 19.1
Hi, I am trying to simulate a small design totaling just 1025 lines of VHDL including the Megawizard parts & test bench YET Modelsim prints a warning
# ** Warning: Design size of 17912 statements exceeds ModelSim-Intel FPGA Starter Edition recommended capacity.
# Expect performance to be adversely affected.
And goes into totally slugged mode making itself unusable.
Why is there such a large discrepancy between the actual size of the design and that claimed by modelsim ? Is this a bug ?
The Megawizard parts are a PLL and two small block rams, the rest of the code consists of a top module joining two lower level modules, then of course there is a small test bench.
Has anybody else experienced this problem ?
Hi RH,
I meant file in ModelSim work libraries.
- Reduce the size of the design (remove the ram and check)
- Neglect the warning, You can simulate the design but simulation may take time.
- Upgrade to Modelsim from SE to FE
https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/model-sim.html
Anand
- AnandRaj_S_Intel
Hi RH,
It is not a bug.
ModelSim-Intel FPGA Starter Edition Software has 10,000 executable line limitations.
The number of line count included all the design files, IP & libraries.
Solution
- Optimize your design by emove your Megawizard Ip
- Use ModelSim-Intel FPGA Edition Software.
Anand
- RH0001
Hi Anand
Thank you for your answer, I understood the limit did not include all the pre-compiled libraries of which there are a huge collection.
Is there a way for me to remove the libraries for all the chips I am not using (about 90%) ?
RH
- AnandRaj_S_Intel
Hi RH,
Anand
- RH0001
OK many thanks for your help, it's like 20 years ago, just leave a simulation running all night haha
