12 years ago --- Quote Start --- Try passing in the '-v' flag when you call aoc to see if you get more debug messaging back. The message you are seeing seems to be caused by the working directory not being set but I'm not sure why that is happening in your case. I ran a similar test on my E: drive and didn't see this issue. --- Quote End --- I try but is the same....
