10 years ago
Memory coding style
Dear all,
I've coded two versions of a single-port synchronous RAM with variable read/write width. However, first design results in 1307 ALMs utilization, while second results in 757 ALMs utilization, both compiled with Quartus Prime 16.0.0 Build 211 Lite Edition. Any idea why?
typedef enum logic  {CHAR, UCHAR, SHORT, USHORT, INT} DataType;
module Memory(input DataType dataType, input  storeData, input  address, input clock, store, write, output logic excep, output  loadData);
    logic  memory ;
    always_ff @(posedge clock)
        case (dataType)
            CHAR:
                if (store) memory]]] <= storeData;
                else loadData <= {{24{memory]]]}}, memory]]]};
            UCHAR:
                else loadData <= {24'h0, memory]]]};
            SHORT:
                if (address != 1'h0) excep <= 1'h1;
                else if (store) memory]] <= storeData;
                else loadData <= {{16{memory]]}}, memory]]};
            USHORT:
                else loadData <= {16'h0, memory]]};
            INT:
                if (address != 2'h0) excep <= 1'h1;
                else if (store) memory] <= storeData;
                else loadData <= memory];
        endcase
endmodule
    logic  memory ;
        case (dataType)
            CHAR:
                if (store)
                    case (address)
                        1'h0: memory] <= storeData;
                        2'h1: memory] <= storeData;
                        2'h2: memory] <= storeData;
                        2'h3: memory] <= storeData;
                    endcase
                else
                    case (address)
                        1'h0: loadData <= {{24{memory]}}, memory]};
                        1'h1: loadData <= {{24{memory]}}, memory]};
                        1'h2: loadData <= {{24{memory]}}, memory]};
                        1'h3: loadData <= {{24{memory]}}, memory]};
                    endcase
            UCHAR:
                if (store)
                    case (address)
                    endcase
                else
                    case (address)
                        1'h0: loadData <= {24'h0, memory]};
                        1'h1: loadData <= {24'h0, memory]};
                        1'h2: loadData <= {24'h0, memory]};
                        1'h3: loadData <= {24'h0, memory]};
                    endcase
            SHORT:
                else if (store)
                    case (address)
                    endcase
                else
                    case (address)
                        1'h0: loadData <= {{16{memory]}}, memory]};
                        1'h1: loadData <= {{16{memory]}}, memory]};
                    endcase
            USHORT:
                else if (store)
                    case (address)
                    endcase
                else
                    case (address)
                        1'h0: loadData <= {16'h0, memory]};
                        1'h1: loadData <= {16'h0, memory]};
                    endcase
            INT:
        endcase
endmodule
    For the one that has the highest ALMs utilization, yes! ^^
    Were you deliberatly trying to target ALMs rather than the internal ram blocks? If you were, then have you verified that the code for both is functionally equivolent?
    Not deliberately targeting ALMs. I just realized second design results in fewer resources utilization.
    Both codes are equivalent, look at it!
