DLiu5's avatar
DLiu5
4 days ago
How can I use Quartus Pro 25.1 sopc-create-header-files tool to generate a jtag master header file?
I am an engineer in Terasic,  I am writting a tutorial for Agilex 5. I use Quartus Pro 25.1,  there is a sopc-create-header-files in \quartus\sopc_builder\bin path, I want to generate a header file in Windows  system.however, I couldn't use it in Win10 system.
I tried it in Nios V command Shell:
even I used Windows WSL:
or in Windows PowerShell:
Thanks for your advice.
Doreen
  • DLiu5's avatar
    DLiu5
    The Quartus Pro 25.1.1 was installed in Windows.
  • PixelPusher's avatar
    PixelPusher
    sopc-create-header-files is a bash script so needs to be run on linux or WSL.
    There looks to be something wrong with your WSL environment because it is missing many basic linux commands such as `rm` `uname` `tr`. You should be able to execute these in your WSL shell
    Once you have fixed your WSL setup, you need to add `quartus/sopc_builder/bin` to your path (inside WSL), because it relies on sopcinfo2swinfo being on your path, and then it should work
    PATH=$PATH:$QUARTUS_ROOTDIR/sopc_builder/bin
    edit: I tested this on a Linux installation that I remoted into via WSL, not a windows installation, so this might not be accurate for windows
    • DLiu5's avatar
      DLiu5
      Dear Sir,
      Thanks for the reply.
       How can I fix this first?
      terasic@DESKTOP-G0MQNOG:/mnt/c/altera_pro/25.1.1/quartus/sopc_builder/bin$ sopc-create-header-files /mnt/c/my_de25_nano_workplace/my_first_qsys_system/qsys_top/qsys_top.sopcinfo --output-dir pd_headers
      Failed writing output file to /tmp/sopc-create-header-files.38.tmp.swinfo sopc-
      create-header-files: sopcinfo2swinfo.exe --input=c:/my_de25_nano_workplace/my_first_qsys_system/qsys_top/qsys_top.sopcinfo --output=/tmp/sopc-create-header-files.38.tmp.swinfo failed
      Did you really test the sopc-create-header-files in the Windows  WSL?  As I usually meet different errors or failure.
      Doreen
