What warning is it throwing? even an info will do related with that.
Look at the assembler report. If it isn't generating a .sof file, it should say why.
I found the problem: the device I choose is an advanced one (this is in the name of the device). That's why the compilation didn't generate a .sof file.
Thanks for your help and to have given your time!! - Altera_Forum
Hi guys,
I've bought a TSE license, but still no generation for sof file. It generate a limited edition like the one without license. What are the things that I have to Check? The device name and the license are correct, is there any possible problem? regards, https://www.alteraforum.com/forum/attachment.php?attachmentid=7119 - Altera_Forum
In the Assembler report, go to the "Encrypted IP Cores Summary" and see if anything is unlicensed there.
