So from what I've read so long as the "IEtotal_intermediate" variable is only used inside of the "always" block then use of the blocking "=" operator will work as an accumulator(would you call it a deterministic local variable?) , but if it was also used outside of that always block it would be used as a flip flop as if it had been a non blocking "<=" operator to start with?(non-deterministic?)
Is it important to also make the distiction you did in the example of + {31 bits , 1 bit input}? Is it just a better notation or will lack of being specific and just adding + 1 bit input cause a problem?
Thanks again
