PWang61's avatar
PWang61
3 years ago
Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10
I am trying SSS communication with Intel® Cyclone® 10 LP FPGA Evaluation Board.
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/cyclone/10-lp-evaluation-kit.html
The project is from
https://www.intel.com/content/www/us/en/design-example/714923/cyclone-10-lp-nios-ii-simple-socket-server-for-c10-lp.html?
Then I got these two errors:
Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10min_trial_edition (AE7C_0014) in current license.
Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/Work/FPGA/C10_SSS/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
I can compile other projects successfully.
Also updated all license (University Program), tried 17.1, 19.1, 22.1std, nothing helped
There is similar post here (@AR_A_Intel)
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Error-292014-Can-t-find-valid-feature-line-for-core-VT-User-FPGA/td-p/1262329
It seems I need third-party license (if same reason), but no idea how/where to get it....
Very appreciate if anybody could help!!
  • Hello,
    Very much glad that the issue got resolved and thank you for sharing the method too. Appreciate it!!
    If you have a new question, feel free to open a new thread to get the support from Altera experts.
    Thank you.
  • Hello,
    Hope you're doing well,
    Any updates from your end based on my previous response?
    Pavee
  • Hello Pei Yuan,
    These errors indicate you are missing a valid license for the Intel Hyperbus Memory Controller IP core. The IP is included as an encrypted file and requires a specific license that is not covered by the standard or University Program licenses.
    Kindly contact your local Altera Sales Representative or distributor to request a license or an evaluation license for the IP.
    Pavee
  • beweibewei's avatar
    beweibewei
    I have the same problem with the reference design for the Intel® Cyclone® 10 LP Development Kit - can you help me as well?
    I am using Quartus Prime Lite 17.1 and getting these messages:
    Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_Opencore_edition (AE7C_000E) in current license.
    Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/.../projects/FPGA/cyclone10LP_10cl025yu256_eval_v17.0.0stdb595/examples/golden_system_ref_design/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
    Any help is very much appreciated.
      beweibewei
      Solved!
      The license file is in the IP folder of the HBMC once the example project ist installed.
      In my case I installed the example project "c10lp_simple_socket_server".
      For instructions how to install the license file have a look into 1-ReadMeFirst.txt (als in the IP folder of the HBMC).
  • AR_A_Intel's avatar
    AR_A_Intel
    Continue support in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
    • JohnJLF's avatar
      JohnJLF
      I have the same problem with the reference design for the Intel® Cyclone® 10 LP Development Kit - I wonder if you could point me to the place where I can find the files.
      I am using Quartus Prime standard 23.1 and getting these messages:
      Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/X/eval_kits/collateral/examples/golden_system_ref_design/golden_system_ref_design/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
    AR_A_Intel
    We received and will respond you in the private message. TQ
    • ms71's avatar
      ms71
      may i get the SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10 license too.
      Thank you very much.
      Maik
    • ms71's avatar
      ms71
      i have the same issue.
      May i get the files to.
      I like to play around with Cyclone 10 "golden_system_ref_design"
      Info (12021): Found 1 design units, including 1 entities, in source file db/ip/q_sys/submodules/q_sys_user_dipsw.v
      Info (12023): Found entity 1: q_sys_user_dipsw
      Error (10003): Can't open encrypted VHDL or Verilog HDL file ".../fpga/c10/dl/cyclone10lp-10cl025yu256-eval-v17.0.0stdb595/cyclone10LP_10cl025yu256_eval_v17.0.0stdb595/examples/golden_system_ref_design/golden_system_ref_design/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
    AR_A_Intel
    Hello
    Welcome to INTEL forum. Further check, can you provide detail below?
    1) License.dat file
    2) Screenshot of Quartus >> tools >> license setup
    3) assembler report .asm.rpt file
    • The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
    And for privacy, you can reply/attach your file in private message.
    • Perli's avatar
      Perli
      • ms71's avatar
        ms71
        i like to try the "golden_system_ref_design" too.
        Unfortunately, i was not able to get the license for the hyperbus IP.
        There is a statement in some readme. I should contact Synaptic Labs
        and ask for a license. I got a node locked license for a newer but
        incompatible version. Useless for me as beginner.
        For now, i can't try the "golden_system_ref_design" and the C10 FPGA board.
        If somebody from intel is reading this request. Please provide the required
        license for the "golden_system_ref_design".
        Maik
  • Yangroot's avatar
    Yangroot
    Just realized that when compiling "golden_system_ref_design" downloading from Terasic, I get the same error.
