9 years agoDoes Quartus II support use of fixed point arithmatic packages in VHDL?
The question is result of what I have read here from Sep 2011: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12082010_811.html Is this still true for Quartus in Nov...
9 years agoYes, it is still true, and the packages are finally included with Q15.1 prime pro. If you dont have a pro licence, you'll have to provide the '93 compatible versions from off the web.
The advantage is it makes fixed point much clearer in your code: signal f : sfixed(1 downto -14); You shouldnt be using std_logic_vector at all to represent integers. You should only be using it to connect to IP blocks that require it, otherwise you should be using numeric_std with signed/unsigned or the fixed_pkg ufixed/sfixed. VHDL does not define any arithmatic for std_logic_vectors.
