12 years agoHi, you wrote too many thread in the forum for your (quite simple) project: http://www.alteraforum.com/forum/showthread.php?t=41385&p=171060#post171060 , http://www.alteraforum.com/forum/showthread.php?t=41213&p=170439#post170439 ....
Here you show only a partial design, that may not get mistakes (I don't know Verilog). We can't see problem from here. Are you assigned the pins correctly ? Is the counter counting ? at a correct frequency ? Does it stop when it has reached the max or does it looping ? Do you simulate your design ? (a little work) Did you have error/warnings from Quartus compilation ? Have you succeeded in configuring FPGA ? Maybe you compile for wrong FPGA. Have you succeeded in configuring FPGA with simpler project : trun on a LED with a button ? please put, in only one thread, your entire project that you have zipped before : see Quartus project menu > archive project OR compress your project directory, if it is not too big, and attach it in one thread.
