13 years ago
cant read map(P)
Hello! I installed ModelSim Starter Edition 10d with sp1 and sp2 ( Quartus II 12.0sp2 already installed) . Windosw XP. all programms on disk d: . When I am trying to create ( or open )project it writes ModelSim Error: "can't read "map(P)": no such element in array. "
I try to reinstall all programms. The same result.
When I try to shut down ModelSim it asks ( Are you sure?) and does not react when I press YES.
And after installation it created icons on working table, but did not create launches in
Start Menu->programms. So I launch them from working table.
I checked all system variables and I did not find variable $MODEL_TECH . Should it be there? And if yes what it be equal ?
What to do? Huge programm is out of use on my PC.
Thank you.
