12 years ago
can someone help on this
Hi all,
I am working on a finite state machine assignment. I have the following code below which i want key_0, key_1, key_2 and key_3 to influence the out LEDR[1..0] and LEDG[1..0]. key_0 and key_1 work very well when pressed the LEDG lights come on but i donot understand why key_2 and key_3 does not affect the LEDR lights when i run the code on the DE2-115 altera circuit board. I have tried to modify the code several times but still nothing happens. Thank you vhdl gurus for helping:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector (1 downto 0); -- Output
LEDG : out std_logic_vector (1 downto 0) -- Output
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,unlocked);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
begin
-- Synchronous Process
process(clk, reset)
begin
if( reset = '1' ) then --Synchronous Reset
Current_State <= closed;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
Process(Current_State, key_0, key_1, key_2, key_3)
begin
LEDG <= "00"; LEDR <= "00";
case Current_State is
when closed =>
if ( key_0 = '1' ) then
Next_State <= closed;
LEDG <= "01";
else
Next_State <= opened;
LEDG <= "10";
end if;
when opened =>
if ( key_1 = '1' ) then
LEDG <= "10";
else
LEDG <= "01";
end if;
when locked =>
if ( key_2 = '1' ) then
Next_State <= locked ;
LEDR <= "10";
else
Next_State <= unlocked;
LEDR <= "01";
end if;
when unlocked =>
if (key_3 = '1' ) then
LEDR <= "01";
else
Next_State <= locked;
LEDR <= "10";
end if;
when others =>
NULL;
end case;
end process;
end Behavioral;
:confused: thanks for helping
