11 years ago
Asynchronous Ripple-Counter without compiler warning?
Hi there,
I needed an asynchronous counter to count the frequencies of ring oscillators.
So I built a ripple-counter by concatenating T-type (toggle) flip-flops. Everytime the input "clock" of such a flip-flop changes, the flip-flop changes its output value:
entity t_ff is
  port (
    -- Input ports
    q_in    : in std_logic;
    rst      : in std_logic;
    -- InOut ports
    q_out    : inout std_logic
end entity t_ff;
architecture logic of t_ff is
begin
  process(q_in, rst)
  begin
    if rst = '1' then
      q_out <= '0';
    elsif falling_edge(q_in) then
      q_out <= q_out xnor q_in;
    end if;
  end process;
end architecture logic;
To build the ripple-counter, I connected the q-out of one T-flip-flop to the q_in of the next flip-flop.
It works as expected, but during compilation with Quartus I get several warnings of the form:
Warning (332060): Node: ripple_counter:my_counter|t_ff:\create_other_ff:1:create|q_out~reg0 was determined to be a clock but was found without an associated clock assignment.
Is there a way of telling Quartus that it should not be concerned about this?
Thanks!
    Afaik, there are very few warnings in quartus you can really suppress. These usually come about because you're doing something that an FPGA isnt really designed for,
    Btw, code appraisal: you shouldnt really read inout ports. The "prefered" method is to declare q_out an out and have an internal local signal.
    Or switch on the VHDL 2008 compile compatability and you can read out ports (like in verilog), to avoid using inout.
    You need to add create_generated_clock for any new clock that comes out of a register.
    Though such method of clocking is not recommended but is possible.
    Thanks for your answers!
    Regarding "create_generated_clock": Excuse my ignorance, but in which TCL file would I have to add these commands?
    Furthermore, by what I was able to find online, I understand that create_generated_clock needs a source clock.
    So is
    ripple_counter:my_counter|t_ff:\remaining_ff:1: create|q_out~reg0
    the source of
    ripple_counter:my_counter|t_ff:\remaining_ff:2: create|q_out~reg0
    and so forth?
    Could anybody give me a hint about how to write the complete create_generated_clock command?
    This is the updated code of the ripple-counter and the T-flip-flop (incorporating the advise by Tricky):
    entity t_ff is
    	port (
    		-- Input ports
    		rst	 			: in std_logic;
    		-- Output ports
    		q_out				: out std_logic
    end entity t_ff;
    	signal internal_q    : std_logic := '0';
    begin
    	q_out <= internal_q;
    	process(q_in, rst, internal_q)
    	begin
    		-- Reset=1 sets the flip flop to 0.
    		if rst = '0' then
    				internal_q <= not internal_q;
    			end if;
    		-- reset = 1
    		else
    			internal_q <= '0';
    		end if;
    	end process;
    entity ripple_counter is
    	generic (
    		bit_length	: integer := 26
    	port (
    		-- Input ports
    		clock				: in std_logic;
    		reset				: in std_logic;
    		run_counter		: in std_logic;
    		-- Output ports
    		q				: out std_logic_vector((bit_length-1) downto 0)
    end entity ripple_counter;
    architecture logic of ripple_counter is
    	component t_ff
    		port (
    			rst	 			: in std_logic;
    	end component;
    	-- Input bit for first t_ff.
    	signal q_0			: std_logic := '0';
    	signal internal_q		: std_logic_vector ((bit_length-1) downto 0);
    begin
    	q <= internal_q;
    	-- Create first T-FlipFlop.
    	first_ff: t_ff port map (q_0, reset, internal_q(0));
    	-- Create (bit_length-2) T-FlipFlops.
    	remaining_ff: for i in 1 to bit_length-1 generate
    		create: t_ff port map (internal_q(i-1), reset, internal_q(i));
    	end generate;
    	process(clock, run_counter)
    	begin
    		if run_counter = '1' then
    			q_0 <= clock;
    		else
    			q_0 <= '0';
    		end if;
    	end process;
    it is all here
    Timing_Analysis_of_Internally_Generated_Clocks_in_Timequest_v2.0.pdf
