druepyNew Contributor3 years agoAltera Register Chain Hello, I'm a student at Georgia Tech. I want to do some timing analysis on flip-flop/register chains. I've read the relevant material for the two devices I have access to - a Cyclone 5 and a Stratix...Show More
NurinaRegular Contributor3 years agoHi,Is this what you're trying to achieve with the design you shared?I removed the location assignments set to reg_out* so it is able to run fitter- they're set too close to lc* signal locations so routing failed. If you don't want your registers to be retimed, setting location assignment is not the right way. Instead, you should use the Netlist Optimization setting to "Never Allow" : https://www.intel.com/content/www/us/en/docs/programmable/683230/18-1/preventing-register-movement-during-retiming.htmlYou may also find this useful: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/hdl/vlog/vlog_file_dir.htmRegards,Nurina
Recent DiscussionsEDA_MAINTAIN_DESIGN_HIERARCHY obsolete?Known issues in Quartus Standard 18.0Setup slack violations?I do not get an eMail with the generated license fileserv_req_info
