Toanatron's avatar
Toanatron
8 days ago
Unable to transmit out of 16550 Compatible UART
Hi I am following the example of the 16550 Compatible UART in the Embedded peripherals IP User Guide and using the provided code I am not seeing any data in the loopback configuration.
Software is Quartus Prime Lite 18.1
Any idea or suggestions is greatly appreciated. I'm not sure if I need to configure any registers?
  • Toanatron's avatar
    Toanatron
    Hi I was able to resolve my issue, the device name was not configured correctly for altera_16550_uart_open().
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi Toanatron​ ,
    Just to clarify, you're testing UART loopback between Uart 0 and Uart 1 as the example below
    Could you also let me know what FPGA platform you're usng?
    Kian
      KianHinT_altera
      Forgot to mentioned, did you try running the c code  example which configures the uart ports and test the  UART0<->UART1
      kian
