FabianL's avatar
FabianL
26 days ago
NIOS V: Systick based timeouts not available when using internal timer
We are using Quartus 25.1 Standard. I came across something, which I would consider a but in the BSP generated HAL files, or at least a major limitation in the usage of NIOS V.
System Setup:
  • NIOS V + JTAG UART
  • NIOS V in internal Timer as Sys_clk_timer
  • BSP Setting:
Problems:
  • The JTAG UART drivers have a timeout functionality based on the systick interrupt to avoid getting stuck, in case there is not JTAG UART connected, so the internal buffer fills up. --> see altera_avalon_jtag_uart_timeout()
  • This used to work fine with:
    • NIOS II Setup (using external Timer)
    • NIOS V Setup with external Timer block as sys_clk_timer
  • But when using the NIOS V internal as sys_clk_timer the JTAG UART timeout does not trigger and when calling alt_printf it gets stuck in altera_avalon_jtag_uart_write
       * No OS present: Always wait for data to be removed from buffer.  Once
       * the interrupt routine has removed some data then we will be able to
       * insert some more.
      while (out == sp->tx_out && sp->host_inactive < sp->timeout)
Analysis
  • When I check the initialization routine of the JTAG UART altera_avalon_jtag_uart_init  by stepping through with the debugger, I realize, the alarm is not setup:
       * insert some more.
    • This is because the alt_ticks_per_second() returns 0
  • During the main() function alt_ticks_per_second() is correctly set to 10 (which is my setting from the BSP)
  • The root cause, is the initialization order in alt_sys_init() within the generated alt_sys_init.c file:
void alt_sys_init( void )
    ALTERA_AVALON_TIMER_INIT ( NIOS_SUBSYSTEM_TIMER_0, nios_subsystem_timer_0);
    ALTERA_AVALON_JTAG_UART_INIT ( NIOS_SUBSYSTEM_JTAG_UART_0, nios_subsystem_jtag_uart_0);
    ALTERA_AVALON_SPI_INIT ( NSC3_SUBSYSTEM_0_ADC_SPI, nsc3_subsystem_0_adc_spi);
    ALTERA_AVALON_SYSID_QSYS_INIT ( NIOS_SUBSYSTEM_SYSID_NIOS, nios_subsystem_sysid_nios);
    ALTERA_AVALON_UART_INIT ( NIOS_SUBSYSTEM_UART_IP, nios_subsystem_uart_ip);
    INTEL_NIOSV_M_INIT ( NIOS_SUBSYSTEM_INTEL_NIOSV_M_0, nios_subsystem_intel_niosv_m_0);
    • _alt_tick_rate is initalized to 0 per default and gets set duing alt_sysclk_init(), called from the INTEL_NIOSV_M_INIT Macro
    • As seen above. The INTEL_NIOSV_M_INIT Macro is called last within alt_sys_init. Hence all other modules do see _alt_tick_rate = 0. Hence assume there is no sys tick timer present. Hence all sys tick based alarms are disabled.
    • NOTE: The ALTERA_AVALON_TIMER_INIT Macro is called first. Which appears to be correct IMHO, so the Timer module works as sys tick timer
@ Altera: Please advise on this issue. Is there any possibility to change the alt_sys_init initialization order?
best regards
Fabian
  • Hi FabianL
    It is scheduled to be fix in the following versions of Quartus :
    Quartus® Prime Pro Edition Software 26.1.1Pro
    Quartus® Prime Standard Edition Software 26.1std
    Jingyang, Teh
  • FabianL's avatar
    FabianL
    Thanks for the information.
    best regards
    Fabian
  • FabianL's avatar
    FabianL
    Thanks for the confirmation.
    Changing the file manually works as expected. But the file gets overwritten every time the BSP gets regenerated. Therefore I personally prefer using an external timer, as this is far more reliable.
    2 Questions remain:
    1. Could you already give a hint, in which version this bug is scheduled to be fixed?
    2. Is there any other side effect of having the NIOS initialized last (as it is currently generated from BSP), besides that timer & alarms are not working for other drivers?
    best regards
    Fabian
    • tehjingy_Altera's avatar
      tehjingy_Altera
      Hi FabianL
      Jingyang, Teh
    tehjingy_Altera
    Hi FabianL
    That issue that you are facing is valid and we are currently looking into it.
    As a workaround currently could you try modify the generated alt_sys_init function to have the INTEL_NIOSV_M_INIT before the rest as shown below:
            void alt_sys_init( void ) {
    For further details refer to the KDB :
    https://community.altera.com/kb/knowledge-base/why-does-the-nios%C2%AE-v-processor-that-applies-fast-jtag-uart-driver-stop-stuck-in-/349481
