Peter01
2 years agoUse case of SLD hub controller
I want to use SLD hub in MAX-V FPGA. The sink of SLD hub would be SLD node in the FPGA fabric. How about the source of SLD hub ? , what is it's input ? (channel and protocol).
Peter01
2 years agoHi Farabi,
I have look the diagram.
Its from AN 693: Remote Hardware Debugging over TCP/IP for Altera SoC.
How the SoC can be replaced with the FPGA to debug over TCP/IP.
I want to debug the MAX-V FPGA.
thank you.
FvM
2 years agoDon't understand why you rely on using MAX V for the project. It has no on-chip RAM and can't implement Signaltap.
There's a principle option to implement hardware TCP/IP stack in FPGA (probably needing more logic cells than provided by MAX V), but it's not supported by any Intel IP.
A processor-less remote debug interface can be easier implemented through other fast serial links.
- Peter012 years ago
Hi Frank,
I can replace MAX V with MAX10.
I have planned this initially but dropped due to complexity.
A processor-less remote debug interface can be easier implemented through other fast serial links.This exactly suits my application . Could you provide suggestion to remote debug (signaltap) .I am aware of using JTAGD (Linux JTAG server) on x86 platform and using USB blaster. But this doesn't fit in my requirement.A hint on use of SLD hub controller for remote debug would be appreciated.Thank you.
