dtopou1
3 years agoUART Core IP (RS-232 Serial Port)
I am having issue with UART (RS-232 Serial Port) Intel FPGA IP v19.2.0 generation on Quartus pro 22.4. The the RX path dose not receive any data. Generated code for the core seams wrong in module "...
mabdrahi
Contributor
2 years agoHi,
Apologies for being late as im try to debug your case and attending other case.
We using GSRD and modify it. By using this method it should nearly accomplish the customer project.
The code generated maybe difference from what you provide.
