Vamsi_21
2 years agoSystem console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Hi, I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document. https://www.intel.com/content/www/...
ZiYing_Intel
2 years agoHi Vamsi_21,
It seems like need the enable the NPDME options. We can narrow down the issue first. Give me some time to find out the possibility that can make the TTK fail reading fail occur. In the meantime, you also can check the connection.
