AdzimZM_Altera
4 years agoThanks for clarifying about your project.
I guess there is no error during the IP generating process and compilation.
But since you're facing some issue with the Arria V device, can you use the example design to simulate your IP in the Arria V?
EBoln
4 years agoI try to simulate... and all signals correct
- AdzimZM_Altera4 years ago
Great!
Can you check the connection between your IP and your design?
And compare it with the example design.
- EBoln4 years ago
I create new project with same qsys file with ddr3 controller
