TSUGI's avatar
TSUGI
1 month ago
I want to use a lot of 10GBase-R PHY on an Agilex 5 E
I want to implement a lot of 10GBase-R PHY with XGMII Interface in an Agilex 5 E-Series.
I need NOT to use 10G Ethernet MAC.
I found some IP Parameters in GTS PMA and FEC Direct PHY IP.
Is it correct to my use-case ?
  • CheepinC_altera's avatar
    CheepinC_altera
    Based on the screenshot alone, I don’t see any obvious anomalies. That said, it’s difficult to determine whether the configuration fully aligns with your specific use case from the screenshot alone.
    I would recommend cross‑checking the configuration against your target requirements and running a functional simulation to verify that it behaves as expected for your intended application.
    Please let me know if you have any concerns. Thank you.
    CheepinC_altera
    Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
