dc3's avatar
dc3
1 month ago
Can't generate F-Tile Ethernet Hard IP Design Example
When I try to generate an example design for the F-Tile Ethernet Hard IP or even the F-Tile Low Latency 100G Ethernet IP, the generating step gets stuck in a loop and will stay that way until I manually stop it in Task Manager. Has anyone else encountered this issue?
  • dc3's avatar
    dc3
    After retrying again, the generation step loops like before. Is there any way I could get a pre-made example design to download instead?
  • Hello,
    May I know which Quartus version you're working with? Do the issue still persist?
    Pavee
    • dc3's avatar
      dc3
      I upgraded to 25.3.1 and now I get this error.
