zener's avatar
zener
1 month ago
Agilex3/5 GTS Hard Ethernet IP 10G example design pin loc and io std wanted
Where can I find any public available dev kit design example for the Agilex3 or Agilex which can implement the GTS Eth HIP as generated by Quartus Pro v25.3 and successfully build a sof file?
A set of pin locations and IO standard settings for the AXE5 Eagle would be optimal, but any other dev kit would be helpful.
According to the "GTS Ethernet Hard IP User Guide: Agilex 3 FPGAs and SoCs" (848477) page 29 under "Target Development Kit Tab" is says:
"Target development kit option specifies the target development kit used to generate the project. Ensure the pin assignments in the .qsf file are appropriate."
But it seems like this will only set the BOARD parameter in the resulting qsf, e.g. when using the Premium Development Kit it results in the following addtion to the qsf file:
set_global_assignment -name BOARD "Agilex 5 FPGA E-Series 065B Premium Development Kit DK-A5E065BB32AES1"
which results in no location or IO standard settings in the qsf and I/O Assignment Warnings in the fitter report after the build:
; I/O Assignment Warnings ;
; Pin Name ; Reason ;
; o_tx_serial_data[0] ; Incomplete set of assignments. Missing I/O standard, drive strength and slew rate assignments ;
; o_tx_serial_data_n[0] ; Incomplete set of assignments. Missing I/O standard, drive strength and slew rate assignments ;
; qsfp_lowpwr ; Incomplete set of assignments. Missing I/O standard, drive strength and slew rate assignments ;
; qsfp_rstn ; Incomplete set of assignments. Missing I/O standard, drive strength and slew rate assignments ;
; i_reconfig_clk ; Missing I/O standard ;
; i_rx_serial_data_n[0] ; Missing I/O standard ;
; i_rx_serial_data[0] ; Missing I/O standard ;
; i_clk_ref_p ; Missing I/O standard ;
; o_tx_serial_data[0] ; Missing location assignment ;
; o_tx_serial_data_n[0] ; Missing location assignment ;
; qsfp_lowpwr ; Missing location assignment ;
; qsfp_rstn ; Missing location assignment ;
; i_reconfig_clk ; Missing location assignment ;
; i_rx_serial_data_n[0] ; Missing location assignment ;
; i_rx_serial_data[0] ; Missing location assignment ;
; i_clk_ref_p ; Missing location assignment ;
; i_refclk2pll_p ; Missing location assignment ;
Whenever I try to assign these myself I get errors like
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 IPFLUXTOP_UXTOP_WRAP(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.intel.com/content/www/us/en/support/programmable/kdb-filter.html and search for this specific error message number.
Error (175001): The Fitter cannot place 1 IPFLUXTOP_UXTOP_WRAP, which is within GTS Ethernet Hard IP ex_10G_intel_eth_gts_1000_6dyx4dq.
or this or other type of layout or clocking type constraint errors:
Error (11216): Output port "O_SYSPLL_C0" of "SM_HSSI_PLL_WRAP" cannot connect to PLD port "CLK" of "FF" for node "kr_dut|intel_eth_anlt_gts_0|ip_inst|sip_inst|u_intel_eth_anlt_gts_csr_top|u__intel_eth_anlt_gts_csr_avmm_arb|o_avmm_rdata[0]".
It would be nice if I could obtain a set of correct and working pin assignment which actually results in a working sof file so I can try to understand what the actual constraints are.
Is there a dev kit as described which the pin assignments are generated or provided or could anybody please provide a set of pin assignments for the above signals for a dev kit?
Cheers!
  • zener's avatar
    zener
    I did not set the board to None. In my message above I said that I sat it to the Premium Development Kit and this resulted only one extra setting, i.e. the BOARD variable in the resulting QSF file as I explained above.
    However, if I build the design it will not generate a sof file, but the resulting pin file will have some default assignments which can be back annotated into the QSF.
    What I would like to obtain is some QSF pin locations and IO standard settings for the GTS 10G ethernet hard IP example design for the AXE5 Eagle development kit. It would be great if anybody knows where I can find these?
    • paveetirrasrie_Altera's avatar
      We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
      If you have a new question, feel free to open a new thread to get the support from Altera experts.
      Thank you.
      • zener's avatar
        zener
        Thank you Pavee, that is one of the sources I've been using as well as the schematics and user guide for the dev kit. Still I have not yet been able to build a working version of the GTS Hard Ethernet IP 10G example design on the Eagle board.
  • Hello Zener,
    The example design does not include pin location or I/O standard assignments when “board = None” is selected. This is expected because the GTS Ethernet Hard IP relies on fixed transceiver resources, which must be mapped based on the target hardware.
    To resolve this, use a dev kit example as reference.
    Agilex 5: https://docs.altera.com/r/docs/817676/25.1.1/gts-ethernet-hard-ip-user-guide-agilextm-5-fpgas-and-socs/generate-gts-ehip-design-example
    Agilex 3:  https://docs.altera.com/r/docs/848477/25.1.1/gts-ethernet-hard-ip-user-guide-agilextm-3-fpgas-and-socs/generate-gts-ehip-design-example
    Pavee
