Two LRDIMM (Dual-Rank or Quad rank) support in Arria 10 GX 570 Device
Thanks for the suggestion with Interface planner.
I found the problem.
As we are placing the EMIF controller in a common I/O column, Need to use same PLL reference clock & reset to both the controllers.
Also, I am using Quartus 18.1 version & it has a known issue as mentioned in the below link.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/emif/2019/error-13149---emif-phylite-systems-sharing-a-pll-reference-clock.html
After using same clock for both the controller's PLL ref clk input & applying the work around I am able to complete the fitter & able to get the pin out from Quartus. It is mapping the pin outs to IO banks from 3A to 3H.
With regards,
HPB
I checked in Quartus 20.3 version.
This issue is not yet resolved. I am seeing same issue with latest Quartus version. But If I apply the work around, the compilation with 2 controller is successful.
What will be the impact of the work around?
With Regards,
HPB
