14 years ago
system console returns empty jtag_debug service.
I want to leverage the system console to help resolve what looks like a jtag chain issue.
After programming the .sof file into the fpga, I open the system console. I tried the same commands than in jtag example section of chap12: Analyzing and debugging designs with the system console.
typing:
> get_service_paths jtag_debug
... returns an empty string, which makes this command fail:
> set jd_path [lindex [get_service_paths jtag_debug] 0]
... since lindex returns -1
There is obviously a nios2 proc in the design with lev3 debug interface and a jtag_uart too.
Any ideas why this occurs? This is using Quartus 11.0.
Any help welcomed,
--M
    --- Quote Start ---
    --- Quote End ---
    The SystemConsole jtag_debug service uses registers that exist in the JTAG-to-Avalon-ST bridge component. The JTAG-to-Avalon-MM master uses this component too.
    I suspect that the UART or NIOS processor debug interfaces do not use the JTAG-to-Avalon-ST component as part of their design, so no jtag_debug service is available.
    Drop a JTAG-to-Avalon-MM master into your design, resynthesize, download, and try again - you'll get a jtag_debug service.
    Cheers,
    Dave
    Hey Dave,
    I am looking at the jtag_pio_cii available from Altera and all there is in the sopc is a jtag-to-avalon-master bridge and PIOs for LEDs.
    So your suggestion seems highly appropriate!
    Thanks a bunch, I will try this out.
    --M
