JohnHaraguchi
1 month agoStratix 10 CKEXT Drive Level 32 GHz Clock
The S10 datasheet lists the CKEXT differential input power requirement as +1.9 to +7.9 dBm at 32 GHz.
Is the lower limit required to meet all performance parameters or a hard limit where the S10 will not function if not met?
If the differential clock power is 0 dBm, does the S10 operate with degraded performance or stop working altogether.
On our assembly CKEXT will be borderline to meeting the minimum +1.9 dBm input level.
I'm planning to test the input power after we receive our assemblies, but was looking for guidance on what to expect.
John
