12 years agoSelf clocking FPGA?
We have a need to power down large parts of our design - including the clock source for the device - but keep portions of the FPGA (Cyclone III, EP3C25) running. There are no other clock sources fed ...
12 years agoThanks Dave - but this design is in production and we are not going to change the PCB for this "feature".
--- Quote Start --- The configuration clock isn't always disabled after configuration, you can use it through the ALTINT_OSC megafunction (in the I/O category). It's not documented though, AFAIK. --- Quote End --- Now this looks promising! Here is the code that pops out of the wizard:module internal_clk_altint_osc_947
clkout,
oscena) ;
output clkout;
input oscena;
wire wire_cycloneiii_oscillator1_clkout;
cycloneiii_oscillator cycloneiii_oscillator1
.clkout(wire_cycloneiii_oscillator1_clkout),
.oscena(oscena));
assign
clkout = wire_cycloneiii_oscillator1_clkout;
endmodule //internal_clk_altint_osc_947 It looks like the input is an enable - the only question is the level, but I'm going to guess logic high... I'll post my experimental results as I try it.
