12 years agoRandom single hold violations on Arria V design that doesn't push timing or util. ???
Hi - I have a design that uses about 20% of the FPGA Fabric on an ArriaVSoc. I've added my own logic to the GHRD. It doesn't push timing (my logic is 100MHz or less), or utilization (see above, eve...
12 years ago --- Quote Start --- there are no analogue buffers in FPGAs. --- Quote End --- so how does Quartus fix timing violations caused by clock skew? (sorry, I'm an ASIC guy where adding delay buffers is how you fix hold vios). --- Quote Start --- LUT based multipliers will have poorer timing performance that the hard ones.. --- Quote End --- you think? :-) /j
