sbj's avatar
sbj
1 month ago
Quartus and power domain
We actually one remaining pending issue with the Agilex chip that we can't get resolved and might need some help.
The basic description is that when comparing the power consumption of the Agilex 5 on our module, to the Agilex 5 on the dev kit, at same temperature, before any configuration, our Agilex 5 consumes about 0.5-1W more.
Besides this, all sub-systems seem to operate correctly (CPU, memory, FPGA, I/Os).
This additional power consumption is worrying though, and we would like to understand it before spinning the next revision.
Regarding the excess power on our board, it might also be a design issue, but we didn't find any hint yet despite multiple deep reviews and investigations.
We already spent several weeks looking at this in every way we could think about, so there is already quite a bit of things we tried out, such as:
-          Measured the power rails, from the outside and from the inside as well, checking if there is any unexpected difference
-          Measured temperature from the outside (thermal camera) as well as from the multiple internal sensors
-          Reviewed power sequence, playing with various combinations to see if it made any difference
-          Reviewed multiple times schematics against documentation and dev kits
The extra power is on the core rail.
Now please look at the attachement:
We collected side observations on an non-configured FPGA. Our board has a temperature-dependent power consumption. So we simply
switched the fan off for a short period and then switched it back on. The main power consumption is on the 0.8 V rail (U500 RAA210130).
A second interesting observation is the internal temperature of the Agilex: L0_0 is significantly hotter than the other three.
When the fan is switched back on, the power consumption returns to its initial value.
Very strange and unusual behavior. Could this somehow help set priorities and allow us to rank the most/least likely directions
for investigating the source of the elevated power consumption?
  • Farabi's avatar
    Farabi
    From your description: "Do you really need the Vcc-to-Gnd resistance of a board that works enough to let us configure its logic and boot the internal processor? No shorts on the board."
    Meaning - the units at your concern are function as expected? I need all this information before I escalate to engineering.
    How about the power consumption in user mode(after device configured+ cooling fan on) , do you see any unexpected current spike?
    regards,
    Farabi
  • Farabi's avatar
    Farabi
    Can you response to my inquiry?
    regards,
    Farabi
    • sbj's avatar
      sbj
      Thank you Farabi for your reponse.
      Please allow me some time to provide you a feedback :)
      Cheers
      • Farabi's avatar
        Farabi
        Noted. I will wait for your reply.
        regards,
        Farabi
  • Farabi's avatar
    Farabi
    The temperature increase is happening before configuration.
    This is abnormal elevated leakage in part of the die. Definitely not dynamic switching power.
    Are you seeing this behavior at only 1 unit?
    Next step:
    1-can you try power up with slower ramp time? (within timing spec)
    2- how many boards manufactured? All showing same behavior?
    3- Is it possible to swap unit on the board with another one? - to see if the issue follows unit or follows board
    4- Please send snap shot of the device top marking so I can analysia the production test history.
    regards,
    Farabi
    • Farabi's avatar
      Farabi
      I cant do conclusion with behavior description.
      I need to check with production test history. We need the snapshot of the top marking at least 1 or 2 units.
      This is critical for checking the rootcause.
      regards,
      Farabi
