15 years ago
PLL error - help please
I am using EP3C25F256. I need to synchronize an internal 30MHz clock with an external 10MHz clock. In order to do so I'm using a PLL which will multiply the 10MHz input by 3 thus resulting with a 30MHz clock which will be used instead of the current 30MHz clock. By doing this I assume that the 10MHz and 30MHz clocks will be synchronized (correct me if I'm wrong). I'm using a dedicated CLK pin as the PLL input. When I compile the code, i get the following error:
Error: Clock input port inclk[0] of PLL "pll_mf:pll|altpll:altpll_component|pll_mf_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Info: Input port INCLK[0] of node "pll_mf:pll|altpll:altpll_component|pll_mf_altpll:auto_generated|pll1" is not connected
How can I fix it?
Thanks in advance.
    They may have the same frequency but their pos edges may not coincide!!
    Sounds like you're not using an appropriate dedicated clock input. Check the clock wiring schematic for the EP3 and if you still think you're doing the right thing, try nailing the PLL that you think you're using down using a placement assignment.
